problem installing pc suite
9 replies · 3,774 views · Started 05 June 2002
Yeap, clean out the disk e.g "Format c" and the answer yes on all the following questions =). No, but wich operative system do you have ? And what version of your 9210 and pc suite ??
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>sorry,i don't understand"Format c"? Iam running windows xp, firmware version 3.82 and the pc suite came with the phone-not sure which version.PLEASE HELP.
I think the poster is referring to the 9210 internal drive. You will first need to make a backup of your c drive (either with pc suite or onto the memory card). Then format the c drive by rebooting the machine and pressing shift+ctrl+F as soon as the Nokia startup screen appears. Then reinstall from your backup folder. Should now be ok... mine was when I had this problem.
3.82?? I thought it went from 3.62 to 4.13.. i could be wrong though.
You can get the latest version of PC suite from the Nokia site... suggest you try this if the formatting doesnt work.
Stop I think the formating was a bad joke
before doing any formating either PC or nokia try the following
Download latest version of pc suite from the nokia site
Make sure that the version works with xp
Re boot your PC
Close down on the pc all other programs running
disconect any perphels
Reboot your nokia (take out battery)
turn phone side off
plug nokia into pc with cable
Run the install programme
chris
Re boot your PC
turn phone side off
chris
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>I've done exactly as instructed and it still stops half way through installing pc suite.When i go to shutdown my computer,just before shutdown, pc suite decides to finish installing then it is halted obviously due to shutdown. p.s i had previously installed pc suite but decided to try and reinstall it when it stopped working.ANY HELP WOULD BE GREATLY APPRECIATED.
Ross in bonnie Scotland
If you previously had it installed have you tried de-installing it via.
Start > Settings > Control Panel > Add Remove Programes
If this does not work then you might be looking at re-installing WIndows XP User posted image.
Andy
Andy
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>When I uninstalled it i done it via add/remove programmes.Why would i have to reinstall Windows xp?
An unhappy 9210 owner.
The problem you describe is familiar, but I'm damned if I can remember what it is that's causing it.
There's an application somewhere that causes the system to stop some applications (setup.exe is an application) until the workstation starts to shut down.
I'm racking my brains to remember what it is that causes this, but it's not a Nokia issue. I'll post the offending application as soon as I remember.....
In the meantime, it may be worth checking the Process list while the setup is stopped and looking to see if there's anything taking up too much processor time.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>TANKERx any help on how to sort this problem would be greatly appreciated
Ross in Bonnie Scotland
