Hip Cam 1.2 problem!
14 replies · 2,572 views · Started 16 April 2003
When i record videos above 120 kb then i cant see them in real one player!!I get permanent loading!!...I tried to play with the qualiti and resolution but nothing.100 kb videos play fine....anyone with the same problem???
yup i got the exact same problem, i just play them in the video recorder, its a bitch but i dont know of any fix :cry:
I found the solution.U install the app...and then u change only the quality ,,resolution..depending on what u want.DONT TOUCH the ...store to...part!!Leave it the way it is.Then record a video..and u will find it by using the real one player in the phone memory.Now u can see videos with no limit.I have 2 videos above 250 kb and no problem!..U can move them to mmc very simple by left click
hhhmmm i got no problem here even i touch the "store to" >phone or mmc :angel:
realone player played the recorded video just fine
Nokia video recorder played the recorded better than realone player coz its full screen :angel:
[quote="daniatt"]hhhmmm i got no problem here even i touch the "store to" >phone or mmc :angel:
Nokia video recorder played the recorded better than realone player coz its full screen :angel:[/quote]
Hehe, you have a "magic" 3650! Everything works for you! 😉 I bought HipCam and I also get that "loading for ever" phenomena! I tried playing the vidoes using Nokia's video recorder and that works, but I had to move the files using FExplorer from E:\Nokia\videos to E:\Videos in order for the Nokia player to show them. Is that so for you too? Also, my phone restarted itself for the first time! Was using FExplorer when it suddenly restarted, hehe!
Hahaha.. yes maybe I have a magical 3650 8) (I hope this is real magic)
No I dont see that "loading forever" hahaha... mabe because the settings that I use for Hipcam are:
Medium Quality
Small resolution
Audio On
Preview On
Size - depends
Store to MMC
All videos recorded by Hipcam is auto-stored in E:\Nokia\Videos
After recording using Hipcam, Replay will bring up Realone player and there it goes. it plays.
Nokia video recorder does not show those videos recorded by Hipcam in its list .. so I have to use a file manager app to move the videos recorded using Hipcam from E:\Nokia\Videos\ to E:\Vidoes
Whether I move them or not, Realone will play them. No loading forever issue.
My phone has no magic... hahaha... there are apps that I cant make it work for awhile but then reinstalling will make it work.
Example is Timetool (the trial version that I received via e-mail from the developer after requesting a copy). I installed Tmetool and the add-ons in the MMC. The app will open properly but the talk time will not talk. I received "no add-on something like that..." so I uninstalled these 3 items and reinstalled the Timetool in the MMC again but reinstalled the add-ons in the phones memory.. Result: Timetool now works :angel:
Another one.. at first I cant make Hipcam work if installed in the MMC. Reinstalling again in the MMC worked but honestly speaking, I dont see the "loading forever" issue that is being reported here.
there are other apps that will not work properly but after few 'thinking" on why and doing some work-arounds.. they work lol...
so not a magical phone :P :angel: its just that most of the apps that I'm trying to install are developed for 7650 not for 3650... and here i am stubborn to install it in my 3650 though some developer replied to me via email that "it might not or might" work 😊)
Some developers said "no, its not compatible" but it is.. they are playing safe? LOL.. not bad play
Hipcam is for 3650 ... it should work with Realone ...
I've seen this problem too in the earlier version.
I think the key is to use.
Medium Quality
Small resolution
Which is about the same as the nokia recorder settings to the eye.
Any higher and you run into problems, and audio goes out of sync too - also if you reboot the phone and go straight to play video this sometimes helps.
Also turn 'performance' off in real one - this helps too.
Not tried 1.2 yet
Best
Will
Cool :angel:
Over here I tried high quality + medium settings - it played OK too but the video is a bit blurred.
Medium quality + small resolution is perfect :angel:
ahah hipcam is not evry good.... i have set to high quality and small resolution and the video is still very blur.... its a complete turn off
[quote="smashpOp"]ahah hipcam is not evry good.... i have set to high quality and small resolution and the video is still very blur.... its a complete turn off[/quote]
u r using version 1.0, version 1.2 ha is much more superior
I just recently installed a CamRec in my 3650. Well, it was cool at first because of a longer recording time with the sound coming along with it. I even put 1000 kb as the size and the quality set as high, with the resolution set as small. But when i try to record something with sounds as background like music coming from a radio or sounds coming from a television, an error occurs, stating kern application exec error. But if you only record something like voices of people only as background, no error occurs. i tried to lower the volume of background sounds like those i mentioned above (e.g sounds from t.v., music from radios) and no error occurs. The problem is, as i do my playback or replay of the video, the background sounds are hardly audible at all. Is it really like this? Or is there something wrong with my installed CamRec? Can't i do my recording having complex sounds such as music as a background?
NO,no.It is not,of the background sounds.You made something wrong,in settings or when installing it.I am sure it is so.
Well, it is because of the background sounds so that is causing the error! :evil: It's because when i try to record the a video with the audio off, the video itself just comes perfectly fine, absolutely no errors. I should know. i experimented on it a lot of times. :robot:
Anyways, the CamRec version i downloaded was only version 1.0. I tried to download Hipcam version 1.02 and it doesn't incur errors anymore. The problem is, when i try to record a video with background sounds, the video only lasts at about a minute and 40 secs the least. When i try to record a video with having the audio off, the video lasts up to 3 minutes and 13 secs. It's logical because as have been said in some forums, video with sound takes up a little more of the bytes off than when you record a video without sound. Take for an example the default 3650 video recorder. The usual average length of recording time it takes without the sounds is about 15 secs. But if you install the update a.k.a nokia_3650 video recorder.sis wherein sounds can be recorded, the video only lasts only up to an average of 9 secs. So don't tell me it's not because of the background sounds that causes the error! :agrue: It's logical that it does.
