Real One
5 replies · 1,875 views · Started 17 April 2003
Hello There Everbody.
This is my first post. I just got a Nokia 3650 and I love it.
Can you get streaming video on the Real Player?
What do you type in for URL? rtsp://
The Nokia Manuel says there is a guide within the Menus but there is none.
What can Real One do that Video Recorder can't?
Thanks.
There is an error in the manual.
In your WAP browser goto http://www.real.com/7650 when you click a link it will launch the content in RealOne.
Thou if you are in the UK streaming does not work as all the Operators are currently blocking UDP packets on their GPRS networks.
RealUK has just done a deal with Vodafone live, so expect them to lift the UDP block soon.
If you want to stream videos I suggest you get Oplayer installed - much better in my opinion.
You can either download it from www.oplayo.com and BR/IR it to your handset or for an over the air install direct into your phone you can signup for one of our playlists and we'll send the player to your phone (free) - see my signature for details.
Best 😊
Will
Thank you very much. That's amazing. Some clips say "not enough bandwidth to play clip"
But all of those are radio. What about Video?
Thanks for your replies Will.
However, those links give me a "unable to connect to server" message.
I did put in the correct info about my language and location.
Any other suggestions?
Your Network operator is probably blocking the UDP ports that Realone is trying to connect to.
Who is your operator & country?
Your better off with oplayer - there is lost of content for it, and it works!
Best
Will
