How to play fullscreen video in RealPlayer
86 replies · 27,324 views · Started 17 April 2003
1- i resize video in virtual dub to 176x208
2- i rotate video 90degress
3- encode video in CanoPus ProCoder to .rm (size 176x208+2pass encoding)
4- change c:\data\realone.cfg atributes (WindowSize and WindowOffset)
5- yeeeeeeeaaaaaahhhhhhhhhh
fuck this small shit video in 176x144 and terible sound quality !!!!!!!!
did it play fullscreen?
also duh its bullshit quality.. not recommended that u watch movies on it (wreck ur eyes) but still good enough to impress peepz.
Can you give some more info on that step please befor I try it?
(I am such a coward)
THAAAAANKS
this is very very nice patch.
RealOne is only one player, who can play in fulscreen.
(VideoMMS is shit, only paly from C😊
C'mon mr.patcher, please post the exact settings for WindowSize and WindowOffset, otherwise its to dificult to play around with the settings :-?
I found it in C:\system\data
It's there 😊
But the question i have, what's the exact settings i should use? I ried putting the window 176x208 but dunno about the window offset. And what program did you use for rotating the vid and resizing it ?
Can somebody please help? I really want this to work, cause i got a 128MB mmc and i wanna squeeze an episode of Family Guy in 😃
1)So to resize the video and rotate it you need (insert program(s) name) -I got dizzy lookin for them, i ended up with unuseful (or so i think) programs 😞
2)To make the Real Player play fullscreen you edit the .cfg file that is in C:SYSTEM\DATA\ but what values for window offset and screen? (after some tries i wasn't really succesful!)
imma gonna download pc suite so i can beam the movie straight to MMC, after i get your answer ofcourse 😃
hey you dummies, you want fullscreen? well, whats the size of your nokia window? right!! 176*208 then thats the setting, and the offset is 0+0+ (offset means a bit space near the up, down, left, size of the video)
if you cant correctly save the new cfg file, just download it to your computer, open it wit wordpad (in notepad you get a single line text, in wordpad you get all the options vertically) and the adjust te setting and put it back in your phone.
good luck. oh i use Stream Anywhere to create *.rm files, and u can use (not tryed yet) VirtualDub for the flip process.
Could you please post or upload that modified realvideo so that we can see that advantages you talk about IRL. 😊
alright alright
http://home.quicknet.nl/mw/prive/defey/The Blunder Years.rm
its being uploaded with 16kbytes, so be patient, its a total of 12.7mb Its a full simpson episode! (20minuts)
ow i did some testing with fullscreen vids, sometimes the player switch back to its original settings, (ow i keep the offset to default. +1+1, i only changed the window size) but when i restart the player and open a video it works again... I recommed to play your self recorded movies with the cam. to play it in the standart player and not the real player.
damn, that infrared is so f**king slow ... from off this post wait 20minuts to leech that movie from the ftp (hope this is not seen as warez... 😞 ) the movie is rotated 90degrees left and size is 176*208 , 15FPS (i think) havent test it bymyself yet!
15FPS is crapped
i am using 10fps and 16kbps music
and 176x208 rotated
this is compromis between good sound and video
i know its crapped, but 15fps was the movie when i downloaded...
For those of you who want the above video but can't get it because of space bars (and you don't know how to) heres the direct link. http://home.quicknet.nl/mw/prive/defey/The%20Blunder%20Years.rm
[quote="EAX"]For those of you who want the above video but can't get it because of space bars (and you don't know how to) heres the direct link. http://home.quicknet.nl/mw/prive/defey/The%20Blunder%20Years.rm[/quote]
Thanks for the URL~
[quote="Evert"]hey you dummies, you want fullscreen? well, whats the size of your nokia window? right!! 176*208 then thats the setting, and the offset is 0+0+ (offset means a bit space near the up, down, left, size of the video)
good luck. oh i use Stream Anywhere to create *.rm files, and u can use (not tryed yet) VirtualDub for the flip process.[/quote]
thanks 4 the tip. i changed it but then i realised my old realvideo stuff wasn't encoded in that size/dimensions so it all stuffed up. me being the lazy bum i am just said 'stuff that' and went back to old times smaller video.
yeah i know your old stuff get f**ktup to, i hope realplayer will release a patch that supports full screen and height and weight settings...
Oh by the way, when you open for the second time a video it will change the settings to default, so u can leave your settings in the phone for the adjusted video's and the old video's just open them twice in realplayer.
oh crap. i even deleted my 2 meg and 4 meg realvideo files 'coz they didn't load properly anymore. oh well.
if got trouble placing files larger then 12mb on my mmc, realplayer says 'cannot play file, its to large'
is this a compression/converting problem or is realplayer telling the thruth 😊 is my file to large? somebody managed to play larger files?
maybe i need to tune that resolution setting better...
the compression/converting works perfect though! First virtual dub, u can rotate and resize it then already, then stream anywhere to create rm file!
[quote="Evert"]if got trouble placing files larger then 12mb on my mmc, realplayer says 'cannot play file, its to large'
nop, realone can play files bigger than 30mB.
i saw many many simpsons episode - one file has about 12MB
now i see whole tails of Startrek Voyager and one tail has about 28MB
I put a 500 kb clip and it was too large!! :x
Real player is pissing me off, that simpsons episode doesn't work, it's an unknown file format 😞
And all my other videos using Stream anywhere, play audio only! (i'm sure i put video) And the size is the same as .mp4 (176 x 144)
