nokia bluetooth modem drivers
8 replies · 40,907 views · Started 17 April 2003
im sure this has been asked before.. but how do you install the nokia bluetooth modem drivers.. im using windows XP and i cant seem to choose the option. im only allowed to tick infra red drivers.. please i really need this one.. there was a query to this before and said to use the built in modem drivers on my bluetooth suite.. please i beg of you, ive been in and out of the forums searching.. and my slow isp connection isnt helpig either.. second, how do you change the bluetooth modem protocol to gprs? i cant change them (bluetooth suite drivers) .. this is th reason why i need the nokia modem drives.. please.. thank you in advance 😞
im using the billionton 1327 suite with billionton usb dongle, downloaded te latest nokia modem driver, my phones firmware is 4.46.. thanks again
You dont need to install seperate drivers for modem
Check this thread for info
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=9890
which is what i exactly hoped to avoid... anyway.. ok, so how do you enable the gprs protocol in my bluetooth software suite?
[quote="renhoek"]which is what i exactly hoped to avoid... anyway.. ok, so how do you enable the gprs protocol in my bluetooth software suite?[/quote]
Do you get GPRS for free? It's a very expensive option by me, I haven't tried it. :x
Best is to ask your Service provider for the settings for your locale
yes its free.. for the time being though.. i have all the connections setup.. the only thing missing is how to get the data to my pc.. i believe if i can install a gprs protool on my phone? pc? (not really sure) ill get the data.. to keep things simple.. i need to get the nokia bluetooth modem drivers installed.. or perhaps, be able to configure my billionton for gprs protocol...
[quote="renhoek"]yes its free.. for the time being though.. i have all the connections setup.. the only thing missing is how to get the data to my pc.. i believe if i can install a gprs protool on my phone? pc? (not really sure) ill get the data.. to keep things simple.. i need to get the nokia bluetooth modem drivers installed.. or perhaps, be able to configure my billionton for gprs protocol...[/quote]
Have you read the thread I suggested above?
You do not need to install BT modem drivers. They are already installed with Billionton software. You can't run Nokia PC Suite and use modem. It doesn't work with Mrouter(PC Suite).
You probably need to configure BT software for GPRS. Not sure if its possible. At least I don't know how as I dont use GPRS. Sorry :x
About BT, what type (class II,III) of BT adaptor will work with 7650, i was going to buy one but in the shop they told me this wont work with ur phone, so what to look for?
[quote="ore"]About BT, what type (class II,III) of BT adaptor will work with 7650, i was going to buy one but in the shop they told me this wont work with ur phone, so what to look for?[/quote]
Not sure about BT class, but there are plenty BT adaptors that work with 7650. Search this forum and have a look. Problem is Nokia will only officially acknowledge that their PCMIA card works with PC Suite. But as you will see in your search, this is not true.
