i had 3 file managers in my phone
*handy file
*seleQ
*Fexplorer
i don't which one to keep.
can you recommend which is best or a better file manager perhaps?
thanks!
*handy file
*seleQ
*Fexplorer
thanks!
My ranking :angel:
1. SeleQ
2. FExplorer
3. File Manager
4. Handy File
The above ranking is my own opinion.
My ranking:
1. eFile Manager
2.
3.
4.
5.
6. SeleQ
7. FExplorer
8. Handy File
DOMI's FExplorer is free,and its awesome,so....
thanks!
i need one more vote!
1.eFile Manager
2.SeleQ
3.handy file
I would recommend eFile Manager from Psiloc. It's awesome, it's light and works perfect. I have never had a problem with it. Anyway, you should come out with a choice, an app. like this is a MUST HAVE.
Does anyone know of a website, that has a comparison of the different filemanagers?
nope. no-one really cares though. they are all pretty much the same except for a few added features and price.
i'd recommend Domi's FExplorer though.. it works.. its free.. and its damn cool. He also has heaps of good plans 4 it.
I would suggest you keep the SeleQ, coz I am using it right now... It is a very good software and does not give any problem at all :P
I have been playing around with the following filemanagers.
Fexplorer v 1.08
Handyfile v.1.5
SeleQ (Can't remember file version)
I tended to go back to fexplorer each time.
That was until I found this http://www.ximplify.com/SeleQ_3650/Main_SeleQ3650.htm
Now. I do not like or want to advertise a specific product, but.. WOW..
Some great additions to a pretty ok program as it was (well fexplorer was a tad better hehe)
Fexplorer really got some competition this time 😮
i personally like FE because it works and its free.
[quote="Seremify"]i personally like FE because it works and its free.[/quote]
Well I have to agree with you there Seremify. I am also just using the Seleq until the trial ends (free is better and yes. fe does work 😉 )
Hoping Fexplorer will get some of the features the new version of Seleq just got.
if there's anything you want; you should email Domi. He's a really good developer because he listens to what the people want.. He also provides tech support even though his program is a freeware program! I know it sounds like I'm advertising but I quite admire his support for his FileExplorer.
Talking about FExplorer, can you guys help with something? Where can I find my messages in FExplorer? I'm using the MMC for my messages. I just can't seem to find where it is...
Browse to this spot and look through the subfolders 😊
are you sure that's the one? 😊 I don't quite understand the folders. But anyway, I'll browse through it again! thanks!
