i'v noticed that the time that the call logs show on my 7650 is excatly a half hr less than the actual time. but the time in the messages log and the time displayed is correct. anyone know y this is n how to fix it?
wierd time difference????
I have the same problem with Screensaver clock time, whenever the screensaver pops up, the time displayed by the clock it's exactly one hour less. It's no major problem but it's weird...
I'm not too sure about your prblem ferrariz (although I recall India's time difference is 4 1/2 hrs from UK (hence the 1/2 hour thing), so read on...
@ deathmonger, since I'm in the same timezone (same country!) and I got this error when the clocks moved forward, here is the configuration for my phone.
Tools/Settings (ajustes) "time & date", insert current time; "auto time update" - activated
World Clock Pro (if you're using it) settings, "time & date", insert current time (should be showing your current time already); daylight saving "on, on , on" auto time update "on"
I don't think the "auto time update" is necessary, since my phones' time have never changed when moving between time zones (not supported by european network operators?), but the above should sort the time problem out.
Paul
I have the Auto update time activated but it doesn't work, I'll try switching it of, I'll see what happens.
Are you people using World Clock Pro?
nope, sorry, not usin world clock pro
btw, what is that? 😮ops:
i bought this damn topic long back. recently i found out something bot it.
well i formatted my phone this week and i did not sync it with the pc as yet. the log timings and all worked fine. the clock on my pc is set by the internet time since i use windows xp and there is a option to get it and the phones clock was set by me as local timings. now after i installed 1 software and sync it with the pc the pc clock and phone clock merge and then only after the sync it show the delay in log of exact 30 mins. i have noticed this problem mainly in india. spoke to a lotta ppl abroad they say it works fine for them so i really dunno. 1 guy from india claims its workin well for him. so endin it all up log works fine until u sync it with the pc.
[quote="ferrariz"]nope, sorry, not usin world clock pro
btw, what is that? 😮ops:[/quote]
It's a clock program made by PsiNT. Gives multiple Time zones and added alarms. I asked because it can affect time on logs
