BT software won't install
1 replies · 2,556 views · Started 18 April 2003
help guys. i've been trying to install the new billionton BT software. After the restart, i get a message that there was a file that was not exported called WBITAPI.dll plus some gibberish, and BT will not configure. Anybody have a clue what this darned file is?
sad thing is even the original CD software won't install correctly now.
i'm on win98SE. maybe i should move up to XP?
cheers.
Hi....
My Mitsumi BT din work wif the software dat came wif it.
After lots of searching, haha.. I found this...
http://www.esato.com/board/viewtopic.php?topic=16284&forum=18#post210026
It worked for me.. Dunno if it worked for U...
try looking ard there or search in this forum.
I'm sure U will find the solution.
8)
