well i am wondring .. i only have got the 16 mega duo card and i am trying to get the bset out of it
1) i downloaded mp3 on the memory card .. but it was not a very good idea after all .. couse it only fits for 3 or 4 songs max :cry:
2)i tried converting mp3 files to mp4 ..hmm well i did it after all but fist the quality was like shit ... so i tried converting it agian with a better quality but it didnt work on the phone + i couldnt play mp4 files in the audio player .. i have to play it using the vedio player !! :cry:
3) finaly i tried to find the realy player fot symbian V 7.0 but i couldn find it any ware .. the only real player avalable it the one for Noke 7650
CAN ANY ONE HELP ME PLEASE !!?!!?!?!?!? ANY IDEAS :roll: :roll: :roll: :roll: :roll: :roll: :roll:
As soon as you're able to get one, buy a 128MB Ms-Duo
A developer is writing an Ogg format player (which may also play MP3) - http://www.o000o.org/projects/symbian/audiomagic/index.php - Should be available soon on Handango. Looks to be far superior to the standard player, and Ogg format files are substantially smaller than Mp3.
But the only solution is to get a bigger card, however you'll probably have to wait - both 64MB and 128MB are in short supply and high demand (at least in the UK) - I cannot get my hands on either until end of April.
normal mp3z are 128 kbps, 44KHz, Stereo ... for a like "CD" quality. that's about 1MB per min ... and that means no more than 3-4 per 16MB stick ...
what you can do it try encoding them at 64kbps .. it wil cut the size into half ... then try "Mono" ....again reduce the size by half ...
see with which quality you can live with.
One more thing you can do it to encode mp3z as "VBR". that will ensure CD like quality ... at the same time cutting down the size by half ...
more info at this thread on my-symbian.com
http://forum.my-symbian.com/forum/viewtopic.php?t=5482&start=30
well thats cool .. i can try changig the quality of the mp3 files .. but i was wondring were can i find a (VBR ) converter ??
i cant find it any where :-?
and agian is their a real player for the P800 ??
there s a soft called diet mp3
works pretty good
Big.Mama
You can find DietMP3 here:
http://www.eniacjia.com/index.asp
