HI,
does anyone know if we will ever get any new masks for photographer?? i was hoping for some new ones in V2 but they still the same
thanks
Photographer masks
Make your own - it's dead easy.
Copy the masks folder to your PC and have a look at them, you'll soon see how they work. I had loads which I made, if I can find them I'll post them up..
Best
Will
[quote="cliveuk"]HI,
thanks[/quote]
I think you can download from the developers wap site. Check their web site
just tried that doc and the wap site gives an under development message
[quote="Anonymous"]just tried that doc and the wap site gives an under development message[/quote]
Ooops, was the same when I tried 6 weeks ago. :x
I've installed the update for photographer, but although the new masks are in the same directory than the old ones, photographer doesn't seem to recognize any of them (except the 3 old ones)... is anyone familiar with this problem?!
i have some on my site. if u are on version 1 install them as they are if ure on 2 then u will have to rename them to work on ur phone, and there easy to make as well. the ones i have work fine
