mp3 on 3650
11 replies · 2,337 views · Started 18 April 2003
if i downloaded mp3 can they be played on the 3650 loudspeaker?
i presume these cannot be used as ringotones then?
does anyone know a good wap or site for downloading decent wave files. I used greyswrld wapsite for my old 7650 but its not working any more for the tones.
thanks for any help.
ps i downloaded the sound add on for the video from the net on my phone wow so easy thanks everyone. its in installer now so if i deleted that file would it not record sound any more or is it permantly in?
i have uploaded both a mp3 short file and a wav file to a site and tried to download them from the 3650 by typing the whole url in but it doesnt work, any ideas?
1. You need exact URL (cAsE sensitive with http:// at start)
2. an Mp3 is very large and don't forget your charged by the KB with GPRS
3. You need an mp3 playback program on your phone to play it
4. Can't you transfer via IR/Bluetooth? Downloading off WAP is the most expensive way.
5. And no they can't be used as ringtones; BUT a WAVE file can.. And if you plan on using WAVE you can use the Nokia convertor which is automatic when you transfer files which are mp3 or wav to the phone it compresses them for you assuming you have it enabled and installed (free).
GPRS is still free on o2 prepay in the UK 😊
are there any good wap sites with wave tones? as I cannot get any wav files to download over air? even though everyone says its possible.
use nowmms.com
and cos gprs wap is still free it means free mms is still around on o2 prepay 😊
that site is down.
has anyone successfully uploaded a wav file to the net and downloaded it directly to their 3650? is there a limit on the file size etc?
i cant understand why it aint working 😞
I uploaded this on to the net
http://www.freeserve.co.uk/sitebuilder/3650/cardigans.wav
it works on the pc
i copied the url exactly onto the phone and pressed go it doesnt work it works for jpegs etc
think ive found why some work, they must be relatively small <300kb otherwise o2 wap wont allow downloads😞
