Original state
3 replies · 2,184 views · Started 19 April 2003
I just got my 7650 some days ago (wowww...)
After installing various apps
I wanted to install realOnePlayer,
so I could play some songs from my own band.
Thats why I deleted all the programs
in <Tools><Manager><Programs>
Now I can't play midi files any more 😞
I made a backup on my brothers notebook,
but he deleted it 😞 😞
Is there somewhere a backup with the original
status of the phone (as it comes when its new)
Or which program(s) do I have to reinstall
to make it like "new" and bring it to its original
state
thanks, bouzouksis
Pal, I strongly doubt you deleted Recorder.app. You should be able to play .mid files in EXTRAS > RECORDER. What you've probably lost are the .mid files.
[quote="deathmonger"]Pal, I strongly doubt you deleted Recorder.app. You should be able to play .mid files in EXTRAS > RECORDER. What you've probably lost are the .mid files.[/quote]
Yes, it's impossible to delete recorder as it is on the Z drive.
If all else fails format the phone. It returns phone to factory state
