the 3 hole above camera
11 replies · 3,240 views · Started 20 April 2003
i read somewhere before that the firtst batch of 3650 have 3 hole at the bak, aboove the camera , to be exact.
but mine don't have that hole, is there any difference on the ring tones volume ??
How come? IS that it?
Cause this is supposed to be the loudspeaker (i think 😊)
yeah it is 😃 cause all the sound comes from it (duh)
hi,
i rember that we have talk about it, and one have made the holes into his phone and he said, that now the sound is louder.
cya amigappc
in my opinion you would have to be pretty stupid to punch holes in those three grooves. yes, it may make the sound slightly louder (which may not even make make difference) but is it worth the risk of fuking it up? it is not as though that section can just be easily replaced with a new cover.
What do you mean there are 3 holes above the camera? Mine doesn't have one... and I don't ever wanna put a hole on my phone! They're right. That part of the casing is hard to change!
we are talking about the three grooves above the lense on the white section. I would imagine that the white section (that is the area around the lense and the area that is on the sides) would be hard to replace as it is not part of the cover. It probably could be replaced at a Nokia Service Centre but i'm not sure about this.
i am totally attracted to the casing that user who posted the pic.... i like the green fancy casings... too bad its not out yet in malaysia... 😞
and the 3 holes... they r pretty useless for me tho.. 😊
I think this was the post that your talking about. Anyways I was the one who poke 3 holes on my phone. Actually it was louder especially in the back but over all I think it was better w/o the holes because the way the casing of the 3650 was made it echoes the sound better. Anyways I bought the phone really cheap and w/o warranty that's the only reason why I made a hole on it but I sold that phone already actually about 5 days after I made the hole and got me me a new one for free with warranty so now I won't even think of opening up this phone since it's has a warranty seal on it.
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=9509&highlight=hole
[quote="deevonn"]i read somewhere before that the firtst batch of 3650 have 3 hole at the bak, aboove the camera , to be exact.
but mine don't have that hole, is there any difference on the ring tones volume ??[/quote]
