I'm using windows 2000 , and trying to convert my all files to NIM in my Multimedia converter program BUT I can't success, giving me message saying (MMConverter.exe has generated errors and will be close by windows-you will need to restart the program.)
and then every thing gone
So please any one knows this problem and can I get any new converter program instead of this. Pleas I much appreciate the help.
I have tried both the converter on the CD and the so called "pro" version that I downloaded from the net. Both of them crash when I try to convert a video file, but work for audio.
Looks like some sort of bug with W2k systems.
Chris
I've used all the MMC versions without a problem on W2K Pro (converting .avis).
What file types are you trying to convert?
db
I tryied with any video clip or movie start converting OK and when reach Converting Encoding give the message (MMConvert.exe . . .etc) and close the window . by the way thanx 4 the help
