connecting to a pc?
12 replies · 2,125 views · Started 21 April 2003
how can I connect my 3650 to my pc if i dont have USB?
bluetotth adapator that runs off serial or rs232 etc? or cable??
help
[quote="daniatt"]get a Bluetooth
Nokia HDW-2 Bluetooth Headset
http://www.expansys.com/product.asp?code=HDW-2[/quote]
i may be wrong but.. i don think he is talking about the headset :roll:
no im talking about connecting the 3650 to a pc without using USB. It is in theroy possible but does the hardware exist?
Bluetooth on the PC or IrDA is the only way. You cannot connect this phone to the PC with USB
Cheers
ok, so is there a bluetooth adaptor or infra red adaptor that works 100% with 3650 and doesnt connect to the pc using usb, is there a bluetooth or infra red adaptor that connects to the pc using rs232 or serial?
Most new PC motherboards have an IR port on them, you can pick up an internal IRDA adapter that plugs into this port relatively cheap, I got mine for under �10.
Cheers
what do the programs that connect the phone to the pc use windows 98 or above Im running windows 95b?
for someone living in UK ur english is very.. odd.
i know there used to be Serial IR ports which used 'tricks' to work with the PC but its a **** load easier just to upgrade to USB. Alot cheaper and easier to use.
As for software; it depends on the drivers. Win2K and XP have a lot better IR drivers than previous Windows incarnations.
lol not quite!
but a job in which correct use of language and grammer is important. I just try and post replies as quickly as possible, thats the main reason for errors.
sorry 😊
Yeah... There's a peripheral available that you just put in your pc (like a CD-ROM) which has USB port in them already... that is, if you have no USB port on your motherboard. Better use USB.
