Removing front cover.
1 replies · 8,672 views · Started 08 June 2002
Can anyone tell me how to safely remove the front cover?? I'm now on my 3rd replacement handset in as many weeks from Orange uk.. this is the best of a bad bunch and only has a misalligned screen. Rather than send it back yet again I'd like to try and straighten it out!
TIA
Huge.
hi, to remove front panel
remove sticker on the bottom of the phone side, unscrew 2 screws.
then use a credit card or a similar one (preferrably slimmer) and insert & slide simultaneously from the antenna part. that's in between. this is to unlock a clip lock inside. there are about 3-4 locks inside. so be careful. just try, not sure if it works on your end.
