sim free and orange
4 replies · 2,656 views · Started 21 April 2003
i am getting sick of waiting for orange to bring out the 3650 😮
is anyone using a 3650 bought sim free with an orange sim card, if yes are you having any problems :multi:
thanks
My experiece is that you should go and buy that 3650. I have always bought _FREE_ phones and I never had a single problem. The thing is, you'll have to call Orange and tell them to Sign you up in services like GPRS and whatsoever (I don't know what services do they offer). Call them.
[quote="pmt_monster"]i am getting sick of waiting for orange to bring out the 3650 😮
thanks[/quote]
I have one and it works perfect. No problem at all 😃
In denmark they even have a portal for download of games from the Orange website. 8)
I have a sim free on Orange. Mostly works fine.
One problem I do have is that the spool icon for a voice message does not work. I have discussed this with Orange and they say that the phone is not supported and they can not help me with this issue. I have also been on to Nokia and they have advised me that there may be a problem with the phone!!
If you can live without the icon - Go for it 😃
Why even bother using the (In the long run) expensive system of having to call a number to listen to voice messages?
A better option is to use an answering machine right on your phone 😃
This one is pretty good Answering Machine for Series 60
Try it. It is deffo worth it. (My 2 cents)
