This ao should have been built in.
http://shop.my-symbian.com/PlatformProductDetail.jsp?siteId=695&javaDevice=P800&device=P800&currency=Handango%20German&catalog=0&sectionId=0&productType=2&platformId=4&productId=66791
New SMS manager!
Hopefully in a future upgrade?
Nice, was eagerly waiting for an app like this :multi:
So did anyone try out this app?
I am wondering that if you move your sms msg into the folders created, is there a way to undo it and easily move them back into the default location?
Also I was unable to reduce the size of the text, which is annoying as I display my list of sms in small text size to fit more on the screen (yeep I know I'm whining now...)
Im trying this software now, ill let you know when I recreate your situations 😊
So I figured that once a sms is moved to one of the newly created folders, they can NOT be moved back to the original SMS location on the phone!
This is not good for me as I do not want to completly rely on a 3rd party app for sms. (I'm just paranoid I know)
All I would like is the option to move the sms back in case I need to store it in its original location...is that to much to ask for!
Unless that is implemeted I wont go for this app 😞
Version 2.0 allows u to move ur sms back and fort to any location u want so olso back to ur mobile
Grtz :angel:
[quote="Yoeppie"]Version 2.0 allows u to move ur sms back and fort to any location u want so olso back to ur mobile
Grtz :angel:[/quote]
thx, just checked for version 2 and it does look promising 😉
Here the description of new functions:
* Copy back stored messages from My Folders to the phone stores. Sent messages to Phone Sent and received messages to Phone Draft (New in version 2.0)
* Password Protect My Folders (New in version 2.0)
* Export your messages in XML format, and view them from your PC (FREE S&W PC Viewer provided (New in version 2.0)
* HotKey function. Choose the type of hotkey to short cut for SMS Folder Manager (Flip Open or Camera Key can be set) (New in version 2.0)
* Font Size changes for Folders and for Viewing Messages (New in version 2.0)
* Use +/- buttons while viewing messages to increase of decrease the current message text size (New in version 2.0)
* AutoStart Module for S&W SMS Manager (New in version 2.0)
* Multiple Moving/Deletion and Viewing for Messages in your Phone Inbox or Sent (New in Version 2.0)
* User Next/Previous arrow buttons for fast viewing of messages stored in My Folders (New in version 2.0)
* Short cut from My Folder to list all the Folders with Unread Messages (New in Version 2.0)
* Sorting of displayed messages (New in Version 2.0)
* Counters for the length of the message you are sending (New in Version 2.0)
Wow great upgrades! I do hope the future upgrade will allow us to send and recieve text via PC 😊
SMS via PC yes yes yes please!
Think i did send a post like this B4!
Though why dont they let you move it back to the inbox? Odd that really?!
Oh well.
