A Few Quick Questions
5 replies · 2,284 views · Started 08 June 2002
if you have a previously backed up your 9210 via file manager (using backup to memory card) -- then you can restore the following files
dbprofiles.db
syssnd.dat
this will restore your profiles...
hope this helps User posted image
From what I remember file manager IS installed in the C drive...So if you format the C drive you've wiped it off.
You'll have to either restore from back-up (as suggested above) or re-install missing programs from supplied CD-ROM using the serial cable. Just install the Nokia PC Suite first. It's that simple.
Thanks for the help, finally got it sorted. Only 1 last problem now, when ever i try and load up Word it errors
"Application Word
Reason Word
Reason Number 1"
I've tried adding a default word document but not sure of the default name? Any help on this would be great!
I think the default name for the Word template is C\system\templates\word\blank or blank.uk
It might even be C\system\templates\word processor\blank or blank.uk. Try a few combinations!
LindaF
