I am planning to order a bleutooth thing for on my laptop so i can sync with my phone, but what if i wanna transfer a large file (movie/audio), how the hell can i save it right on the mmc and not on the phone ram (to small)?
Bluethooth question
already found out how to do it, for people wondering how, u can set that incoming messages will be saved on the mmc card
You can also use PC Suite and Select MMC there to transfer the file.
great i use pc suit with infra red, it works te same as with bleutooth i geuss!?
that better then store incoming messages on the mmc, i just want to keep those stuff seperated.
can somebody tell me how the hell i use the software provided with the conceptronic usb bleuthooth adapter?
i want to make a bleutooth-serial connection to my computer and then use nokia-suite! but there are so f**king many options and settings, and pair-pin-codes :roll:
dunno how it works, are there easyer programs for bleutooth?
Search the forums for billington and MSI and bluetooth and you should find some suitable articles 😊
thx! but already found out, works great, only i expected a higher speed, its now 20kbytes a sec. well atleast much faster then IR (8kbytes sec)
it seems in my experience to transfer quite a bit faster from phone-->PC than PC-->phone :-?
