Phone won't turn on ;-(
11 replies · 2,578 views · Started 22 April 2003
Turned my phone off the other day and it won't start up anymore.
When I press the button to turn the phone on, the keypad lights up and the screen displays the nokia logo which fades, the logo is displayed again then fades....this happens about 3 or 4 times then the screen goes blank.
Have had the phone plugged in so believe it is charged.
Any tips short of taking it back to the shop and having them have a look at it? Any key combos i can hold down on startup etc?
Please help!
Ewan
Press F8 for save mode, 😃 lol no sorry , serieus: i have no idea, are u sure the phone is charging?
this is what i normally have when my battery's are empty! Do you see a horizental line when the screen is turning off
Ev,
Yes - I get the horizontal line - what does this mean? Is it good?
Thanks for the quick response earlier.
Ewan
If its new should be under warranty; so don't play around with it in case you void the warranty. Just take it back to the place you got it; usually they can arrange for a repair; if not then they'll refer you to the Nokia Repair Centre.
j2k,
I installed and used the irRemote trial software, used it for about 5 mins then uninstalled - but that was about 10 days ago.
Ewan
Ah okay, there are just rumours that irRemote seems to be killing some phones, with the exact symptoms you describe.
If you uninstalled it 10 days ago, I doubt it would be that though.
Cheers
that horizental line is what i get when the power shut down (empty battery) !
maybe is your adapter broke?!
try using another adapter (maybe u can try it at your local phone shop, just ask if you allow to TEST not buy, the adapter there!)
or, like already said, send (t or d? 😊 )your phone back incl. the adapter to nokia.
Is the concensus that my power adapter is broken or is my phone broke?
Will a firmware flash do the job?
Ewan
[quote="fergu5"]Is the concensus that my power adapter is broken or is my phone broke?[/quote]
Personally, the symptom doesn't sound like the battery isn't charged. If the logo fades out and comes back on, it still has power, not just cutting out straight away.
Yes.
hi,
try to get into the safe mode.
i dont have testet it:
turn ur phone on, press and hold the pencil button.
if it doesnt work try the reset code
*#7370# ?!
maybe any software have a little problem.
i get a problem if my phone restarts.
it says
Prog. geschl. (prog closed)
Startup
WSERV 7
and i cant get into the menu. only the hotkeys and basic phone i can use.
*ot*
i have also installed the irRemote 0.93 and have testet it. after 2 days i have deinstalled it and now i use an older version.
*/ot*
cya amigappc
hi,
*#7370# ?!
it says
Startup
WSERV 7
*ot*
*/ot*
cya amigappc
p.s.:
or try to get the phone memory empty.
remove the batterie and let the phone 1 to 2 days without any power suply?!. and then test it again.
