PC Suite - File transfer engine operation failed?
3 replies · 3,473 views · Started 22 April 2003
Everything else in PC Suite is working fine, but when I try and transfer a file or an image from within the program, i get "file transfer engine operation failed". I also get an "unexpected error" when I try and backup my phone or it freezes on "closing programs". It all worked fine the first time I tried it!?
I've removed and reinstalled PC Suite, but still get the same problem.
Any ideas?
I HAVE REALY SAME PROBLEM. SOMETIMES PC SUITE CRASHES AND THEN FILE KERNELL ERROR. AND I CANT USE BACKUP - ERROR WHILE CLOSING APPLICATION
I used to have problems like that;
try:
1. Do not switch user in XP or allow the login screen to display (once you've 'quick switched' it stuffs up IR transfers)
2. Do not run anything on the phone (try closing all apps)
3. Disable photograph transfer on Windows
