I have read in few of the postings that , irremote can down 3650 , and the phone would not start.
Are there any other application beside this one. I had previously installed irremote 9.1 , 9.2 , 9.3 on my 3650, but the application doent work. I have tried pressing the button for all the romote function , but i dont think it was working.
Whats the truth behind this. I really want to impress by Girl friend but ........ ? Help me.
Is it safe to install irRemote in 3650
Install it on the MMC and you should be fine. If your phone won't boot, simply remove the MMC and it should start up again.
Cheers
no, installing irRemote and first of all psint.dll istn safe!!!!!
and remove MMC sometimes is not enought and reason is flash new FW or i saw one man that must change board in the phone. (in servis indeed)
i installed 0.94 in my 3650,
but my tv don't react to the remote, so i guess i ll wait untill psiloc make especially for 3650 :P
but moine is working fine :roll:
[quote="deevonn"]i installed 0.94 in my 3650,
but my tv don't react to the remote, so i guess i ll wait untill psiloc make especially for 3650 :P[/quote]
what tv u got? i got it working with samsung vcr, samsung tv and nec vcr on my 3650.
i think the prob is with the soft and the 3650, cause it was fine when i use 7650, my tv is sharp btw :P
try moving closer? make sure u r near to tv.. i found ir on 3650 to be weaker than a lot of other devices (such as the real tv remote).
weel i 've tried, and still unsuccesfull, bte which irremote version do you use and what firmware on the 3650?
0.93 on 2.41
i'm using 0.94 in V2.50
WHAT is the latest version of IRremote,AND what version is the best. :roll:
There is now version called Total irRemote.
http://www.psiloc.com/?id=prod&nrp=94
AND what is the safest ver.for N3650 :roll:
ok,i'll ask SO:WHAT version of IRremote do all of you use :roll:
Total irRemote 1.00.
thanks,has anyone used the newest version 1.01.
I am now, just upgraded.
THANKS for answering,now i'll install 1.01 too.
Got Total irRemote, had a good time turning off all the TV's in Dixon's and Sony Shop! 😃
Yea i have also installed Total remote on my 3650,and it is great.IT really works on a lenght of 3meter.
I have the total.irremote.v1.01 installed. After that I also installed the 18plus2_CRACK.sis which makes it registered.
But the remote doesn't seem to work with my tv. Does anybody have this installed and is working?
Can you tell me where to get the crack? hehe. Thanks a bunch
[quote="Anonymous"]Can you tell me where to get the crack? hehe. Thanks a bunch[/quote] due to forum rules,we cant give you it
install 0.91 this version is the best n u need the full key so post ur IMEI i will generate the key for u before using it make sure that r did`nt activated the infrared option!!!
hey if you got the crack can u please fwd to me at [email][email protected][/email]
thankx
sam
