How can i do to uninstal game or appl. Who re install..
3 replies · 2,013 views · Started 24 April 2003
...In game directorie or in principal menu like game downloaded directly from my-symbian by wap? I se try with "c" button but error message appear. Could you help me please? Thanks for your attention regards,ambre
I think you are asking how to uninstall programs.
1. Symbian Apps
Go to Tools Folder, then choose Manager
It will list all your Symbian Apps, and if you press the left soft key
you will get the option "Remove" ( which is the uninstall)
2. Java Apps.
Go to Apps
Select the Application you want to remove, then left soft key
and select "Remove" ( which is the uninstall)
hope this helps.
There are more appl. Who 're instaled and not listed,like camerafx,spycam,handy.They 're listed..Excuse my bad english and thanks very much for your help
