How does ZipMan work along with GoBoy???
2 replies · 1,962 views · Started 24 April 2003
I've got ZipMan, and I zipped up a large ROM file on my PC. When I go into my Fexplorer and find the zipped file and click on it, it gives me this message:
Zipman system error!
Am I zipping the files up incorrectly on my PC, what exactly are the steps to making a zipped ROM work in GoBoy?
Your meant to send the files over into the Messaging Inbox. This is done by sending files via IR or Bluetooth (and NOT PC Suite).
So as long as I send it through ir (not PC Suite) then it will recognize the proper format?
Thanks!
*goes off to try this*
