Opera Error
4 replies · 1,260 views · Started 24 April 2003
after i've re-install opera, I got following error and cannot start Opera.
Program closed
Reason code KERN-EXEC
Reason number 3
Please help.
Happened twice to me. Normally when I uninstall opera and reinstall it, the problem went away.
It might be because Opera needs to be registered... It would make since if it noticed that a previous copy of Opera was once installed. You need to find ALL files associated with Opera to do a clean un-install.
further to my reply from another thread regarding KERN-EXECs
a KERN-EXEC 3 is an unhandled exception - this could be an internal exception raised by the programmer. Report to Opera.
More info on KERN-EXECs can be found at
http//www.symbian.com/developer/techlib/v70docs/SDL_v7.0/doc_source/reference/SystemPanics/KernExecPanics.html
Although I've un-installed and re-installed, it is still coming back. Anyway, I've that solved using the suggestion from a chinese forum as follows.
1. Un-install Opera
2. Delete all directories and sub-directories with name Opera
3. Re-install Opera
4. Copy C:\system\apps\opera\opera.ini to c:\system\data\opera and make it readonly.
It works for me now.
