Appforge Booster with R2D
6 replies · 2,394 views · Started 24 April 2003
Heyas
Anyone installed Appforge Booster with firmware R2D? If so, any problems? Any system improvements? Pros/Cons?
thanks in advance
Seems to work as good (or bad) as it did under R1x.
Make sure to download one of the later releases, as otherwise you have backup/restore problems.
I guess now most of you have R2A, anyone have any problems with appforge booster? Pros/Cons? What version?
cheers
I had problems with an erlier version of Appforge Booster and R1D, but with the latest version of booster it seems stable. Havent for R2D yet though so I couldnt tell you about compatibility there.
The latest booster version is 3.5.0 (0633).
Z.
I have many problems after installing Appforge.
Application Lists dissapper
Memory and space used
I just do not use programs that are Appforge (VBasic).
I would prefer to run real programs anyway as they will be much more efficient in the P800
The dissapearing list not only occurs with appforge but with any game or ap that I install 😞
That's right. I do not have Appforge booster installed, and I lose the list sometimes as well. Shutting it down and restarting it again solves it however
