Good day.
I just had my phone upgraded to 4.13 and transfered most of appl in C drive to my 64MB Memory card. (including all files from Csystem/install to Dsystem/install)It was a success. From 1.2MB, my C is now at 2.6MB.
The problem is, whenever I press WRITE FAX at Messaging, a Note appears. Saying, "Note Not found". I tried re-installing all_nokia_9210_datav413 but with no luck.
What can I do? Did I delete something? Help!<font size=-1>[ This Message was edited by apcaw on 2002-06-10 1402 ]</font>
Help! Having problems w/ Fax
You need to reinstall fax - download the fax.sis file from here http//www.nokia.com/phones/productsupport/9210/downloads_sw_413.html
i tried re installing fax already from nokia's product support, but no luck. Still when I try to write a fax, Not Found comes out. Aaarrgghh. What's wrong? ![]()
Calling all Forum Elders, Review Masters, and Helpers... Help! Aaargghhh. Have no clue. Tried reformating my device and reinstalling all data, but no success. What do I have to do?
Can you edit the account settings at all? Menu\Tools\Accounts. It could be that fax is installed but the fax editor isn't!
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
On 2002-06-12 1237, LindaF wrote
Can you edit the account settings at all? MenuToolsAccounts. It could be that fax is installed but the fax editor isn't!
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
No I couldn't. When I g to account settings, only PCMail and SMS appears. I guess you are right. How do I get that program? Thanks.
Please try the search in forum menu "fax" this is a known prob with 9210 only answer is to reinstall all the data after a clean format
