i have tried to put doom onto my 3650 eventhough the programme was for the 7650. it didnt work. is there an updated version anywhere or am i doing something wrong?
doom
Most likely you are doing something wrong (but since mind reading is not an exact art, it is hard to say what that is 😉 ).
Use the Search function on these pages. Use, e.g., a search string like this: Doom AND 3650
If that doesn't find post with similar problems as yours, come back with an description of what, exactly, you are attempting to do and what happens when you try that (whatever it is).
i am installing the individual files onto my phone in the order that the readme file sugests. when i come to play the game it just tells me that the data files are missing, eventhough i have installed them onto my phone. can you help?
Install the MMC patch
sorry to be such an idiot but where can i get an mmc patch from????
[quote="tosspot_ohyeah"]sorry to be such an idiot but where can i get an mmc patch from????[/quote]
Check here 😊
MMC patch SUXXX
it doesnt work (or work only to 1% off ppl.)
DOOM is not work on 3650 (or work without sounds only to 2% off ppl.)
[quote="ivomir"]MMC patch SUXXX
DOOM is not work on 3650 (or work without sounds only to 2% off ppl.)[/quote]
It works if you install it properly. :roll:
the patch worked perfectly. thank you all for your help.
are there any other games to a similar standard that are free to download?????? or applications that are free????
