Anyone know what file in P800 is the CDA?
8 replies · 2,440 views · Started 24 April 2003
I need the file that is CDA CDA162001 R3A16. I know it can be restored to phone.
This i know becours i lost the firm update on the CDA after i tried to restore my phone..
Restored the phone after update.. and CDA is back to CDA CDA162001 R2A04
The version number is in the file: c:\system\data\cda_version.txt
You can edit it with jText
[quote="betatester"]The version number is in the file: c:\system\data\cda_version.txt
You can edit it with jText[/quote]
Ah, is that what happend. The TXT changed, not the firmware? Then i still got latest product, but need edit TXT file.
Thanks 😃 :angel:
In the upgrade process with SE, I ldiscovered that the CDA file is no longer on my P800 (unless it is hidden elsewhere on the hp). A check on the system info and I find that the code reference does not appear. What does CDA do for the P800? I mean, what is its function? Have I lost something very important?
[quote="Ghazalie"]In the upgrade process with SE, I ldiscovered that the CDA file is no longer on my P800 (unless it is hidden elsewhere on the hp). A check on the system info and I find that the code reference does not appear. What does CDA do for the P800? I mean, what is its function? Have I lost something very important?[/quote]
I'm not 100% shure, but what i found out thanks to this forum is this. The CDA version is just a file. The CDA software is still ok. All that happend is the cda_version.txt got deleted. This is just a small file. Where it's found.. look over 😊
and so... someone can post it for release R1D? Please 😃
Thanks 😃 😃
Something interesting.
According someone this forum said, CDA just a file.
It will lost when format internal disk.
I backup my phone immediately when I brought.
Several weeks later upgrade to R2F (P800C)
Then format internal disk and restore data.
CDA information lost.
I want to find out what's the problem. So restore initial backup
when brought.
But the CDA version still not appear.
Question:
If the CDA version is in a file, why the backup won't keep the file?
very very strange.... 😮
After the upgrade, the CDA was R3A. After I restored my phone, the CDA was back to R1F and I had lost the mp3 player in flip-closed mode (if my phone is set to Dutch)
