how can i install Remote Control for P800 ??
can some one tell me how ?
i have a bluetooth device conected on a USB port
how can i make an IP address on a bluetooth ??
How can I connect to the install of Remote Control for P800 on my Home PC??? The software is installed and the "start server" icon works...BUT HOW DO I CONNECT TO THE PC (IP is known) FROM MY P800????? [/b]
[quote="Wintheskinz"]How can I connect to the install of Remote Control for P800 on my Home PC??? The software is installed and the "start server" icon works...BUT HOW DO I CONNECT TO THE PC (IP is known) FROM MY P800????? [/b][/quote]
I think we are talking about two different remote controls. This thread is about making your P800 a remote for you existing homemedia appliances like, TV, VCR..etc..
The remote you are talking about allows you to use your PC from your P800. You have to setup your PC as a server for this. Fore more info on this, do a search here.
Hey, I couldn't get this RC to work, it says connected by it gets disconnected after trying to auth, what the hell, the usernames and passwords are correct.
Do you have a router installed on your homenetwrok?
No.. I found out, my username's first letter is in capital on computer but not phone. 😃 But.. I can't connect now, so strange. :cry: But I think I can solve it myself.. Tomorrow. :robot: Could be the No IP thingie's fault..
if I have a router is there a different step I need to take so the program will work?
Yes, because you will not have a permanent IP. I suggest you visit www.no-ip.com and read around, it works 😊
