is there a zip file for p800 and can you use pda software ie like windows ce software.
You can use JZIP to unzip files in your P800, and no, win ce software doesn't work on the P800, only Symbian c++ and JAVA.
If you are a VB fan, you can look at MobileVB (AppForge).
