When i try to add a sound to an MMS i get this error msg:
Program QMapp
Reason code KERN-EXEC
Reason 3
Then MMS crash.. And i'm not able to add sounds.
Can anyone help me fix this with out a reset of phone? I tried to reset restore, but same problem appear. I need to find out why this happends. Also if possible witch files to replace to fix it.
Hmm.. Well, it looks like you might have a corrupted file in your system. My suggestion would be to do a backup and then format the internal disk(number 5 in the hidden service menu).
[quote="Raven"]Hmm.. Well, it looks like you might have a corrupted file in your system. My suggestion would be to do a backup and then format the internal disk(number 5 in the hidden service menu).[/quote]
I've just updated to latest firmware, and after restore the problem came back. So i need to know what file that does this.. hehe. So i can replace just that file. I have sooo many sms mms etc.. that i dont want to redo the phone if i can fix it with out format.
Hehe.. I think it will be tough locating that particular file mate.
If you don't wan't to lose your sms' etc. I think you can just copy the mail folder over to your PC to save it, and copy it back after the format using either the file manager for PC or P800.
I haven't done this myself so I'm not exactly sure about this, but maybe it's mentioned before on this forum..
