Is it ok to format both internal and ext mem?
3 replies · 1,793 views · Started 25 April 2003
Is it ok to format both internal and ext mem? Or will i get in trouble restarting the phone then? :roll:
it's quite okay to format both, I know this because i've done it 2 times already.
When you do the internal format, the P800 would reinitialize itself to the factory setting. After formatting, the P800 will turn itself off, then after you have re-started the P800, it would then ask you for the basic preference, i.e. language...
??? But why are you doing this ???
I think Tommen has been, er, exploring his file system after suffering problems with the phone. 😮
[quote="enterprise"]it's quite okay to format both, I know this because i've done it 2 times already.
??? But why are you doing this ???[/quote]
I'm Having trouble with several progrms crashing.. All error codes have 3 lines. First on differ, but 2 last are always the same:
Program ******
Reason KERN-EXEC
Reason number 3
Then the prog crash. An example is when i try to insert a sound to a MMS. I then get this message:
Program Closed
Program QMapp
Reason KERN-EXEC
Reason number 3
