Changing the colour scheme
13 replies · 2,853 views · Started 25 April 2003
Handy Day has a mode for it.
You have to pay for it, but it is relatively useful.
Think you can get it on trial.
Or you can try program ColourScheme. I think its freeware because it doesnt require you to register. Everytime you want to change colour, you have to install the SIS file, not as good as Handy Day.
I can upload it when i get an OK from the moderators.
cheers
[quote="wiggy"]thats not my normal colour , just showing what it can do !![/quote]
With you coming from Manchester and all, I did worry for a while 😃 😃
PS. Some of the colour schemes do seems rather pointless.
Mainly the ones where the text is almost the same colour as the menu background 😮
There is a new app to change color schemes and customize the menu's even more:
http://www.psiloc.com/?id=prod&nrp=93
Did not try it yet... :roll:
The psint one is very complicated, you have to know the name of every window and text 😞 if it had a demo view (allowing you to see the changes as you make them and you dont have to exit everytime you change just to see the changes)it would be a lot easier..
