Whats in your package
10 replies · 2,208 views · Started 25 April 2003
I got in my package:1) Nokia 3650 Made in Finland,Blue;2)Charger Made in Finland too;3)CD-ROM with PC suite for N3650;4)Manual with The official Nokia warranty inside;5)And other documentation.P.S No MMC card.And the box is small,more larger than the box of N7210(but not big),CAUSE i seen someone has the bigger one.
Carefull - my MMC was inside a little cardboard 'envolope' amongst a load of leaflets which looked just like a usless piece of nokia bumph which very nearly ended up in the bin!
Will
yeah... the MMC is difficult to see. Try to scan every little thing found in the box. Maybe the MMC is there.
my mmc was in an envelope.
1. Nokia 3650 Asian model made in *shrug*.. anyone know how to tell?
2. Manual
3. Charger
4. Battery
5. Little box containing big manual, quickguide, MMC in an envelope, advertising pamphlet, big quick guide poster, another advertising pamphlet
hi,
my mmc was also inside the phone. if u have the white labeld nokia mmc it can be, that u havent recognized that the mmc is there.
cya amigappc
No,when i was buying my 3650,i asked if there was a MMC in the package,he said no MMC card.I am not sad,i will buy a 64mb or 128mb MMC card.
but there should be a FREE 16mb MMC... I suggest you get it. Maybe the seller got it! 😃
