Any Ideas anyone
7 replies · 1,885 views · Started 25 April 2003
i am looking at completely deleting the whole memory of my phone since it is becoming too cluttered, so what i need to do is back my contacts, they are the only important thing on my phone, i cannot be bothered to write them down manually, but the nokia data suite does not seem compatable with my bluetooth adaptor! any ideas?
I can think of this only,try sending them all to a phone the supports vCards and then send them back after the format. 😃
Here's one idea.
Select them all and e-mail them to your phones e-mail addy.
Format your phone.
Collect the e-mail
Save the contacts.
Best
Will
[quote="willbrady"]Here's one idea.
Format your phone.
Collect the e-mail
Save the contacts.
Best
Will[/quote]
That qualifies as a solution if GPRS costs are cheap enough! 😊
i aint got the email setup and cant be bothered, could i send all contacts via bluetooth to my pc then send then back another time?
You what??
It takes longer to type the damn question then it does to get your phone setup with e-mail!
If you can't even be bothered to spend 5 mins - you'll spend 30 mins sending them to your PC one at a time and then you have to send them back again!
Up to you pal, only trying to help, but if you 'can't be bothered' then there is not much we can do to help is there!
Will
Hi,my question may be a subject for another topic but since this discussion has to do with email does anyone know of a way to add attachments to my emails other than pics,sound clips or notes?Thanks.
