Datasuite Problems
3 replies · 2,103 views · Started 17 October 2001
Hi All,
Im having trouble with accessing my Nokia 9210 from the desktop of my PC. The icon in the system tray says connected but when I double click the nokia icon and try to access it to drag and drop files, it shows the not connected icon.
I have tried to restart the pc, reboot the nokia, checked the cable, but all to no avail - anyone else expereince connecting problems?? If so, how did you overcome them?
Any help appreciated.
If it's a new connection and you're not worried about back-ups etc remove the sub folder with the name of your Communicator from HKEY_CURRENT_USER/SOFTWARE/NOKIA/CONNECT6/EPOC DEVICES.
This should force the software to view the Communicator as a new device next time it's plugged in and often fixes this problem
If you don't have the latest version of PC Suite (1.02), try downloading it from Nokia's Web Site. That might fix things.
