Will an FM Radio for P800 ever be possible?
2 replies · 2,482 views · Started 26 April 2003
Sorry if this is a really stupid idea, but I'm not an electrical engineer...
I know the P800 doesn't have a radio, but I was just wondering if it is *conceivable* that a radio could be developed for it? I don't know if the internal hardware could be tuned to the FM freqency band, and if SE provided any API's to be able to do so.
Would be a nice feature that I would use, and is also on the Nokia phones. But it might be limited by hardware. But, hey, you can't have *everything* and, on balance, the P800 still rocks.
You can get a FM radio for the P800 over here, http://www.p800er.com/product.asp?id=50
[quote="Anonymous"]You can get a FM radio for the P800 over here, http://www.p800er.com/product.asp?id=50[/quote]
Thanks for that, I do appreciate the reply.
However, I consider that to be an FM radio headset, that just happens to communicate with the P800. I'll probably buy the HBH-60 Bluetooth headset, and don't want to have two headsets.
