mp3go/volume... strange thing
7 replies · 2,050 views · Started 26 April 2003
about the volume... while using mp3go and hdd-1 earphones... strange thing... first when i plug hdd-1 in i can hear the music from the phone a little bit, then after some �plugging in and out the sound dissapeares and the volume in the earphones incresses to the acceptable volume. Enybody else? Why is this happening?
Where can I find a copy of MP3go?
I can't find the damn thing anywhere...
check this http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=10626&highlight=trick
another solution for the headset-problem:
put the plug into the phone veeeeerrrryyyyyy slowly and you will have the sound coming through the headset only...
Hi Sleepless, can you tell me if the music from the 3650 comes out of both of the HDD-1 speakers? Also, what is the sound quality and volume like?
well, yes, att first the sounds comes out from bouth the phone and hdd-1, then after some tricking it only comes out of hdd-1... then the volume is good.. the sound ok. but then there is another thing... when you have this "high-volume" you can not answer the phonecall with hdd-1. irritating...
Maybe my 36 is different than yours, but my mp3's sound terrible... not even stereo... maybe it's just me... (not!)
KAX, that trick of yours ain�t good... then the sounds is loud from both the headset and the phone... and i happened to be in the buss when i tested it, now aware that i was not the only one listening to my music 😞
