Newbie 3650 - Got some questions..
9 replies · 2,072 views · Started 27 April 2003
1. Any way to turn off the annoying camera sound?
2. Anyone know of any fancy covers for the phone? (The original doesn't quite do it for me.. )
3. I have an animated gif that I want to use as background image (using extended profiles pro). Although the file is only 15kb, the animation lags like h.. Any ideas why?
You really should do a search before asking..
Yes you can turn off the camera sound - go into profiles and turn off 'warning tones'
Yes you can get fancy covers - go to you local market or goto www.expansys.co.uk
Dunno, never tried animated gifs - do a search
Best 😉
Will
[quote="Roverdude"]
3. I have an animated gif that I want to use as background image (using extended profiles pro). Although the file is only 15kb, the animation lags like h.. Any ideas why?[/quote]
they never work properly.
[quote="willbrady"]You really should do a search before asking..[/quote]
You're right, of course.
I tried to search, but didn't get the answers I wanted. :cry:
[quote="willbrady"]Yes you can get fancy covers - go to you local market or goto www.expansys.co.uk[/quote]
My local market only got those standard nokia-covers.
As far as I could see, so does the expansys website. (I am looking for fancy covers, not cases.
Thanks for the input though. 😃
Got another question for you..
I tried a html-browser program a while back. It seems that the prog cached some files in my phone memory (not the mmc), and I suspect that the files are still residing inside the phone memory somewhere.
(I suddenly lost over 1mb of the valuable phone memory..) :roll:
Anyone know if such browserprogs usually place their cache in the same folder, and if so, wich?
(Like the newbie I am, I can't remember the name of the browserplugin.) :cry:
Ahhh - do you means these?
Try here: http://l8shop.net/Products/Covers-Fascias-Nokia-3650-Covers-Original-Nokia.asp
Hey that's mine!! 😃
I got it for 20 euros only! They're ripping you off guys! 😃
[quote="willbrady"]Ahhh - do you means these?[/quote]
Yeah, those are the ones that they got in Norway (except the pattern-ones).
What I am looking for are the unoriginal covers, as long as they are tight-fitting.
Know of any?
Under Profile... open personalise any one of the profile... off the warning tones... activate that profile... it is done ... try to snap a photo... no more sound 😃
