Hi Guys,
I was wondering...does any of you got to uninstall the applications included in this Suite? I wasn't able to find the "uninstall" file for the Power Data, for example.
Any idea?
Thanks,
[email protected][email protected]</a>
Hi Guys,
Any idea?
Thanks,
Yep;
I had the same problem.
The only solution is to download a demo version and install it over the version off the nokia essentials.
After this it appears in the list and you're able to uninstall it without any problems.
Ren�
