Help! IR Remote control
6 replies · 16,692 views · Started 28 April 2003
I have downloaded the new IR Remote Control for the P800 and I can't get it to work for some reason.
Has anyone else had any problems?
Please HELP...
P.S. It's downloaded to my phone fine but when I turn on the IR in the control panel the remote control won't load up and it gives the message:
"Program closed. Reason Number 555".
[quote="flighty"]I have downloaded the new IR Remote Control for the P800 and I can't get it to work for some reason.
Please HELP...
Thanks[/quote]
You should have the IR turned off and not on!!! IR Remote starts IR by its own!
I have also experienced the above problem. The IR program does not initialise the IR hardware on its own and requires a manual activation. This causes the 555 IR error, and worse still prevents the phone from being turned off. Any ideas?
Had the same problem.
Couldn't turn off the phone and the screen was blank.
Tried to restore. Nothing worked.
Al last I took the battery out and put it back in the phone.
Now I was able to put on the phone again and everything worked as before.
Hi there,
I have a real problem with this application, the installation was fine but when I try to do some work on it, it doesn't work with me, I tried it with more than one brand but nothing happens even if the Infrared is turned off..
help please...
