I've downloaded tons of .imy files, then put them in my P800 after that I tried to test them from the P800, when I try to hear each file I get this message "Playback error".....
Why is that happenning?
is .imy file not supported in P800?
PLEASE GUYS, I need help ASAP!!!.
Thanks.
Not sure why you are having this problem but the P800 does support imy files, I have a few and they play fine.
The question would be why would you want them, with support for midi and wav as ring tones and hundreds of thousands to find free on the net.
Open them with a notepad and see if they look strange compared to other working .IMY files.
I got sent a imy file from a mates t68i, its really cool as it makes ur phone vibrate like a heartbeat but i just get playback error. Ive attached it if you wanna try
