Dual Sim Adaptor
11 replies · 3,499 views · Started 29 April 2003
I've never seen one in the flesh so given the amount of space in the 3650 this may be a silly question, but can you get a dual sim adaptor for this phone? If so where in the UK would sell them, and are there any that people recommend?
Thanks in advance,
Nic
Nintendo sells them with Pokemon cards for two bucks! And the ice cream man has em too.
Many thanks Licki, 😃 I shall check out your source, but just in case you may be wrong I may still keep an eye on the thread some more, to see if any one else has any ideas. 😉
Thank you for providing the link!
It's nice to have a dual-sim adapter. However, my mother had one for her 3210 and the bad thing is that you have to turn off the power to choose which SIM to activate.
This might cause unwanted problems on your phone. There are times that it will not respond.
Please thoroughly check the adapter using any demo phone before using it on your phone. An unlikely damage will cost you more.
Cheers Samb
Thanks for the link, I should have stated that I had searched a number of forums and strangly did a google search. I could not find any specific ones for 3650, of course I never looked through each hit. This is why I asked the question to the forum to see if any one has actually used a dual sim card.
Thank you anyway.
I dont think they make one for the 3650 I could be wrong
but i havent come across one. if i do i'll let you know...
try SIM MAX gsm sim back-up tools. Allows STK on-line mobile numbers switching. U can program up to 12 mobile numbers into the master sim card. I have 4 numbers programmed into my master sim. Very easy to use. In 3650, goto SIM-STK- and you can select the number you want and it will switch over automatically. Don't even have to turn of the phone.
Hope this helps.
