Is there any tool for 3650 that can view what the f... is eating it's memory, cause I can't start Opera because of low memory.
Memory consumption
You can try this one, not too bad at all.
http://my-symbian.info/7650/applications/applications.php?faq=2&fldAuto=187
does it show the free memory or used memory in the graph?
In all free memory view it shows all memory. In spy mode, it shows the memoey (heap) of the selected program (thread)
how can i use this software? what benefits will i get?
Incompetible with 3650...
**Sorry for the wrong spelling.. 😮ops:
it's not incompatible. just install it anyway, and it works fine. Just can't do it through PC suite, but transfer it to the phone and install it from there. when it says "file incompatible with phone. abort installation?" just select "no".
Hmm.. Will it harm for doing such "force" install? :P
Well, of couse it will not harm anything... That's just like installing an program on one PC and on an other but for the second the manufacturer wants you to buy the same software again... so don't think, just do it 😊
(but plz don't do it if the program uses any phone specific things like the memorycard of 3650 on 7650)
But maybe i just took your question to seriously 😉 :P
try FExplorer from mysymbian.com .. works great and its 3650 compatible (supports MMC) and its FREEWARE!
