YEAAAAH. great app. but memory is needed 😊
i tested Opera for long time and long time i have problem how to run with BT connection. (problem with enouth RAM because BT conn. need aprox. 0.5MB) and here is the reason.
You must change in settings CACHE SIZE from 512 lower. I have settuped 128. And if i using GPRS and not BT i settuped to 720.
So and first you must start OPERA and then start BT conn.
And WORKS !
rocks 😊 😊 😊
I'm using it also and its cool :angel:
I like it 😃
i always get the memory error message when installing Geopod and Opera.
'tis killing me!!
keep getting memory errors..
1. when i install it via PC Suite it gets memory error when running
2. when i copy installation file via IR (no pc suite to messages) it gets memory error
3. when its in manager and i try to install i get memory error
but i have 2.2meg free!!!!
plz help me. its driving me nuts.
http://my-symbian.com/forum/viewtopic.php?t=6163
check this out... 😃
i think theres a prob in the RAM memory not the storage memory
can someone plz tell me what that link says regarding the memory error? i'm not registered.
What does exactly OPERA do?
[quote="Seremify"]can someone plz tell me what that link says regarding the memory error? i'm not registered.[/quote]
I expect it is about the same as this one.
http://allaboutsymbian.com/phpBB2/viewtopic.php?t=11877
[quote="fearce"]What does exactly OPERA do?[/quote]
Its an internet browser. 😮 www.opera.com
