P800 MIB & Stunt Run, How do we pause and exit?
2 replies · 2,544 views · Started 30 April 2003
While playing the game, is there a way to pause and exit without having to end the game? What I dont now is close the flip which is very annoying. Sometimes you just get a message and it exits automatically and you have to restart the game..
Pushing the jog dial wheel in pauses the MIB game but there is no save function that I have found :bad-words: Highest score 27,970 level 5 and can get no further :2gunfire:
Stunt Run is a load of pish that you wouldn't want to save or pause for that matter. I've deleted it for the tiny bit of memory that it used and have not looked back!
Cheers
simple close your flip, MIB will save your position, also if you get disrupted with a call, it will continue.
mine highscore 33550
muh
