P800 Prob: Calendar items invisible
2 replies · 2,002 views · Started 30 April 2003
After I shut down and turned on my P800 the other day, all of my Calendar items became invisible. They are still there, as alarms and reminders keep popping up, but I won't see any of them in the Calendar app.
I've tried to do a full sync with Outlook, but that didn't solve the problem. Turning the phone off and on again didn't help either.
Any ideas and hints?
Have you inadvertently set the displayed folder to an empty one?
Check the folder drop-down in the upper right of the screen and set it to 'All'.
*laugh* oh, well, Jules, you were right.
It's not that I would use computers for years and have devices almost constantly around me. 😃
Thanks, this solved my problem.
