opening gprs session
1 replies · 2,507 views · Started 30 April 2003
I wrote a Java application which needs a httpconnection over gprs or csd in order to work. However, a gprs session or csd session doesn't begin if I don't quit that application. This is not a problem on 3650. With 3650 the application makes a connection as soon as it begins. Am I doing something wrong or is this a bug of 7650?
Hi esramete,
I am facing the same problem.
Have you resolved it ?
If yes then do let me know..
Thanks,
Chintan
